Messaggioda Grixx » 04/04/2013 - 22:35
Erik Czakoi ha scritto:Ciao friends...if possible, I will join the GT Championship I choose the BMW Z4 my car [:1]
Hi you are welcome, the champ will start on 29 April 2013, see you on track [:138]
Erik Czakoi
Nome e cognome: Erik Czakoi
Messaggioda Erik Czakoi » 04/04/2013 - 23:53
Than you Grixx I can not wait championchips [:27] See You the curcuits [:15]
Andemagre
Nome e cognome: Andrea Boccafoli
Messaggioda Andemagre » 05/04/2013 - 10:55
Ragazzi perdonatemi, mi sono inscritto poco fa e, immagino di no, ma volevo sapere se è possibile usare Skin personalizzate.
Messaggioda Grixx » 05/04/2013 - 11:00
No per gli Special Event non è previsto usare skin personalizzate,
verranno però utilizzate per il campionato [:1]
Messaggioda Dartan » 05/04/2013 - 11:05
per gli special no... per il champ si.
Cia [:1] [:15]
Andemagre
Messaggioda Andemagre » 05/04/2013 - 11:06
Grazie Fabrizio! Allora ci penseremo per un eventuale campionato! [:15]
Erik Czakoi
Messaggioda Erik Czakoi » 05/04/2013 - 11:38
I think it is so good as it is [:308] the skin is not important [:15] The most important thing is that the car to be competitive...engine power, the tires and brakes,is the most important [:308] [:138]
Erik Czakoi
Messaggioda Erik Czakoi » 05/04/2013 - 12:41
For me the best car:Aston Martin V8 Vantage [:308] I choose this...the car's performance is very good,the tires, the brakes are all fantastic [:138]
Erik Czakoi
Messaggioda Erik Czakoi » 05/04/2013 - 15:55
Ciao,Hello My Friends... I would like to ask,will have to use the Data Acquisition Plugin the GT Open Championchips? [:11]
Messaggioda teddyfaster » 05/04/2013 - 15:57
Erik Czakoi ha scritto:Ciao,Hello My Friends... I would like to ask,will have to use the Data Acquisition Plugin the GT Open Championchips? [:11]
Yes Erik, the data acquisition plugin is mandatory for all our championships...so, is also mandatory to send us the telemetry file for every time you will do the pole position and/or catch the podium.
.tail
Nome e cognome: Thomas Truffo
Messaggioda .tail » 05/04/2013 - 15:59
for sure, you must to use Data Acquisition Plugin for all our championships.
For the moment thet Plugin isn't request for the special event
TheShtick
Nome e cognome: Andrea Stagno
Messaggioda TheShtick » 05/04/2013 - 16:00
yes, and remember to enable it using ctrl + m when you are in game or going to this file "DataAcquisitionPlugin" in rfactor directory to find this "Logging Active On Startup=" and there you must write 1...it must be like this: Logging Active On Startup=1
Erik Czakoi
Messaggioda Erik Czakoi » 05/04/2013 - 16:07
Thank you for the information,and where to send the telemetry data?only 1-3 podiums pilots to be sent?
Messaggioda KaiserMEM » 05/04/2013 - 16:13
Erik Czakoi ha scritto:Thank you for the information,and where to send the telemetry data?only 1-3 podiums pilots to be sent?
poleman and drivers on the podium [:11]
Erik Czakoi
Messaggioda Erik Czakoi » 05/04/2013 - 16:22
Thanks again for the info [:1] and where to send the data?to this address? telemetrie@racingworld.it [:1]
Ultima modifica di Erik Czakoi il 05/04/2013 - 16:38, modificato 1 volta in totale.
Torna a “GT Open 2013”
