[SILVERSTONE] Pre & Post gara
Erik Czakoi
Nome e cognome: Erik Czakoi
Re: [SILVERSTONE] Pre & Post gara
Messaggioda Erik Czakoi » 16/05/2013 - 14:02
derek44 ha scritto:
Erik Czakoi ha scritto:Hello,Ciao my friends...First of all, congratulations to the 1-3 pilots,and in turn everyone who finished the race in...I was very bad in both races,struggled in both races brakes and tire degradation... [:18] the brakes were very big problem [:16] [:28] I hope that the next race will be luckier...have to do a good adjustment on my car [:1] in particular, there are always problems with the brakes...Otherwise, all was not anyone was more serious incidents... [:15]
See you next Race:Paul Ricard Curcuits!!! [:11]
C.I.A.O...
Did you try to enlarge the air intake for brakes? :-D
About tyres disintegration, try to decrease negative camber and connected to that decrease air pressure too, you have to go out for a stint of 10rounds at least and then control tyre temperatures, correct values are hotter in the inner side and lower in the external side, center must be a medium value between the other two
Thank you Andrea,many thanks to your help...but I could not solve the problem [:57] [:18] [:18] Can someone send me a setup???pleas???
Because then I'll have to finish this Championchips!!!because you can not compete if there are still problems with the brakes [:18] [:18] [:18]
Erik Czakoi
Messaggioda Erik Czakoi » 16/05/2013 - 14:12
My friends I finish the GT Championships...Good luck to you all !!! There are always problems with the brakes!!!So you can not compete!!!
C.I.A.O...
Messaggioda KaiserMEM » 16/05/2013 - 14:19
Erik Czakoi ha scritto:My friends I finish the GT Championships...Good luck to you all !!! There are always problems with the brakes!!!So you can not compete!!!
C.I.A.O...
the problem is in your device? [:18]
I have sent you my setup...
Erik Czakoi
Messaggioda Erik Czakoi » 16/05/2013 - 14:48
C.I.A.O...
Marco thank you very much for the Setup!!!very good this setup!!!BRAVO,BRAVO,BRAVO [:15] [:11] [:11] [:11]
now very much helped me this setup [:308] [:308] [:308] [303]
Marco Grazie Mille [:27] [:27] [:27] [:96] [:96] [:96] [:160] [:160] [:160]
SEE YOU THE-PAUL RICARD CURCUITS [:199] [:344] [:142] [:142] [:142] [:96] [:96] [:96]
Messaggioda KaiserMEM » 16/05/2013 - 14:56
the merit is of my team-mate [:11]
Erik Czakoi
Messaggioda Erik Czakoi » 16/05/2013 - 15:43
KaiserMEM ha scritto:the merit is of my team-mate [:11]
[:1] [:96] [:96] [:96] [:92] [:92] [:92] [:160] [:160] [:160]
federik21
Nome e cognome: federico snoboda
Messaggioda federik21 » 16/05/2013 - 20:12
min**ia oh, io non ci capisco una se*a di assetti e ho corso con il default [:1] per fortuna non mi sono impegnato troppo perchè so stato coinvolto in tutte e 2 le gare in incidenti non causati da me [:8]
Per fare snowboard bastano 2 cose: voglia di farsi male ed un buon ortopedico.
nitro77
Messaggioda nitro77 » 17/05/2013 - 19:47
Rosmarino scusa ho appena visto il tuo reclamo ma non capisco proprio perchè tu lo abbia fatto...in quel punto te sbandi perdi il controllo della vettura, mi tagli la traiettoria e mi centri in pieno...non ho avuto nemmeno il tempo di frenare...secondo te come facevo a sorpassarti a sinistra... mahh! l'errore lo hai commesso te non capisco io cosa c'entri..
Messaggioda uff51277 » 17/05/2013 - 20:10
secondo me' potevi evitarmi benissimo.....se avessi rallentato prima siccome eri dietro di un paio di secondi e non di mezzo secondo.....
nitro77
Messaggioda nitro77 » 17/05/2013 - 20:38
guarda che hai sbandato e sterzato all'ultimo quando ero molto vicino a te e non potevo evitarti..comunque visto che hai fatto tutto da solo commettendo te l'errore non capisco proprio perchè tu mi mi abbia tirato in ballo visto che poi venendomi addosso mi hai fatto uscire di pista facendomi perdere tempo...in teoria potevo fare reclamo io ma visto che non sono un rosicone ho lasciato perdere perchè sono contatti questi che in pista ci possono stare..comunque deciderà la Dg...era solo per capire il senso del tuo reclamo che ancora non ho capito tutto qui.
Messaggioda uff51277 » 17/05/2013 - 20:42
ciccio mi sa che il replay propio no l'hai visto.....guardatelo bene.....
nitro77
Messaggioda nitro77 » 17/05/2013 - 20:46
se vabbè....la prossima volta cerca di non uscire di strada và..
TheShtick
Nome e cognome: Andrea Stagno
Messaggioda TheShtick » 17/05/2013 - 21:01
si potrebbe abbassare la regola del 107% ad un...105%?
Messaggioda Dartan » 18/05/2013 - 00:11
no... [:3]
Mario MAZ
Nome e cognome: Mario Mazzelli
Messaggioda Mario MAZ » 18/05/2013 - 12:42
TheShtick ha scritto:si potrebbe abbassare la regola del 107% ad un...105%?
ci stanno gia le pre qualifiche da superare mi sembra che bastino .....possiamo introdurre gli esami del sangue.... per controllo Antidoping [:1]
Torna a “GT Open 2013”
