La 24 ore di Le Mans dove si può vedere?
FJM
Messaggioda FJM » 14/06/2007 - 00:28
tecnicamente no [:1]
però se hai tempo di smanettare un pò... questo era su un forum inglese... incrocia le dita e spera [:1]
<Satorian> do the following:
<Satorian> go to your internet explorer settings -> connection -> proxy settings
<Satorian> proxy: 217.195.246.83
<Satorian> port: 8080
<Satorian> click OK, close the dialog, close IE
<Satorian> then open windows media player
<Satorian> tools -> options...
<Satorian> then, 'network'
<Satorian> under streaming proxy settings enter the same proxy as above for all services. close dialogue. close WMP.
<Satorian> then go to http://www.rtl.nl/sport/rtl_gp/rtlgp/
<Satorian> click on "RTL GP livestream"
<Satorian> a new window opens, containing the player window and RTL content
<Satorian> then it will request the DRM license, showing a pop up
<Satorian> click ok/accept
<Satorian> it will get the license from the geolocation service
<Satorian> this is now done through the dutch proxy you have entered in IE and WMP
<Satorian> once it has done so and you can play the stream (or shows it loading), you should revert your proxy settings to the way they were before
<Satorian> now you can also open http://www.rtl.nl/(channel=service,p...nt.xml/800.wvx in a dedicated WMP instance
racingjoy
Messaggioda racingjoy » 14/06/2007 - 09:27
allora, come ho scritto sull'articolo della flying lizard la gara, oltre che da nuvolari, viene trasmessa anche da canali privati come MotorsTV e SpeedTV. In genere io trovo quasi tutti i canali su www.streamingx1.com, ma ancora non ho controllato se questi ci sono.
SpeedTV ha solo la parte notturna, mentre MotorsTV fa tutta la gara...
se ho altre notizie ve lo faccio sapere... ma anche voi se ne avete comunicate !!!
