LMS Silverstone
Lemans2003
Re: LMS Silverstone
Messaggioda Lemans2003 » 13/09/2008 - 13:45
l'endurance c'est le mans
Lemans2003
Re: LMS Silverstone
Messaggioda Lemans2003 » 13/09/2008 - 13:53
24 HOURS OF LE MANS
A.C.O. 2009 rules - Silverstone press conference
By Gabriel Portos ⋅ September 13, 2008
In a pretty packed Silverstone Media Centre de A.C.O. unveiled their long awaited 2009 rules. Several team managers were present as the need for definition regarding next years’ plans is critical at this point. The main highlights include rebalancing the diesel vs petrol equivalence, reduce costs, increase safety and postpone the next rule revision to 2011 instead of 2010.
Don Panoz, Patrick Peter and Stéphane Ratel were thanked initially to reinforce the link with the ALMS, LMS and FIA-GT series. Immediately afterwards, the headlines of the new rules were revealed. In the words of A.C.O. President Mr. Jean-Claude Plassart the rules intend to preserve “sportive competitiveness”, “safety improvement through speed reduction” and “cost reductions to ensure the preservation on motorsport” with special accent on environment areas (including noise) and conomy of resources consumption. Le Mans also wants to profile itself as the big laboratory of new automotive technologies: hybrids, alternative energies, etc.
The rules were designed by an A.C.O. commitee of 4 top executives advised by an engineering team. The guiding lines for the rules were the following:
Technical
1)A new equivalence in diesel vs petrol engine performance for the LMP1 class.
2)Ensure equivalence in performance of open and closed prototypes, allow and encourage GT1 engine utilization in prototypes.
3)Maintain the performance differences between LMP1 and LMP2.
4)Make LMP2 and GT2 more accessible for privateers. [:37] vorrei sapere come fanno con porsche in giro
Safety
1)Reduce performance on all classes looking at a target of a 3.30 quickest lap around Le Mans.
Cost reduction
1) Increase tyre change time to reduce tyre consumption.
2) Allow only standard production engines in LMP2 (including GT2 engines)
3) Mandatory use of one engine for 2 races (exception made of the Le Mans 24 Hours) [:28] [:28] della serie copiamo la f1 [:40]
4) Align GT1 and GT2 with FIA-GT rules for 2010 [:11]
Daniel Poissenot gave more details on both areas:
For 2009:
LMP classes
-10.5% performance reduction in diesels
-Turbo pressure reduction on diesels
-10% restrictor reduction on LMP2
-The rear wing measures will be reduced
GT classes
-The rules are still being discussed with FIA and constructors (Ferrari, Porsche, Aston Martin, Corvette) for the final definition
-Minimum weight will be increased by 25kg in GT1 , 20kg in GT2
-Also a reduction of rear wings will be applied
-Restrictors will be reduced by 2% in GT1 , 5% in GT2
-30 degrees Celsius will be the maximum temperature allowed in the cockpit
-The cars will have to be 5mm higher from the ground
In general:
-The refuelling and tyre change will still be non-simultaneous procedures. The tyre changes will only be allowed to be performed by 2 mechanics using only 1 gun.
-No pre-heating of tyres will be allowed.
-1 engine must last 2 races in the LMS.
-A 112db noise limit will be implemented for 2009.
-The fuel for both diesel and petrol engines will have a % of eco-fuel.
-Rules will be created for hybrids in cooperation with constructors (e.g. the announced KERS system will be measured and controlled before defining rules)
-For 2010 homologated hybrids will be fully included in the rules.
Re: LMS Silverstone
Messaggioda Marco23 » 13/09/2008 - 14:00
Sì, non ci sono stravolgimenti. Era stato un pò tutto annunciato. Rimango perplesso sul motore per 2 gare e sulla riduzione delle dimensioni dell'ala posteriore. Mi intressa invece la nuova equivalenza e il tentativo di "unire" di più ALMS, LMS, Fia-GT e Le-Mans. Stiamo a vedere...Torno alle 15.00, Ciao!
Lemans2003
Re: LMS Silverstone
Messaggioda Lemans2003 » 13/09/2008 - 14:03
a me l'idea del motore per 2 gare fa schifo... sempre a copiare la f1 [:42] [:42] rimango perplesso su più spazio privati in lmp2... invece è positiva l'unione dei regolamenti di tutti i campionati.. che questa scelta sia stata spinta da acura e aston per correre alms e le mans? [:13]
Lemans2003
Re: LMS Silverstone
Messaggioda Lemans2003 » 13/09/2008 - 14:15
L’ACO donnera la possibilité aux teams d’y participer en hybride, sur invitation, mais hors classement, dès 2009.
e quindi la peugeot e l'audi ibride?????????????????? [:9]
Ultima modifica di Lemans2003 il 13/09/2008 - 14:18, modificato 1 volta in totale.
FJM
Re: LMS Silverstone
Messaggioda FJM » 13/09/2008 - 14:16
Lemans2003 ha scritto:a me l'idea del motore per 2 gare fa schifo... sempre a copiare la f1 [:42] [:42] rimango perplesso su più spazio privati in lmp2... invece è positiva l'unione dei regolamenti di tutti i campionati.. che questa scelta sia stata spinta da acura e aston per correre alms e le mans? [:13]
quella del motore è una regola SENSATA... e che è già nel FIA-GT da anni... non facciamo i "pecoroni"... in F1 ci sono un sacco di schifezze ma alcune regole hanno senso
MA CHI L'HA MAI SCRITTO CHE CI SAREBBERO STATE AUDI E PUG IBRIDE?????
Lemans2003
Re: LMS Silverstone
Messaggioda Lemans2003 » 13/09/2008 - 14:20
la peugeot potrebbero presentarla oggi... [:15]
FJM
Re: LMS Silverstone
Messaggioda FJM » 13/09/2008 - 14:21
siete proprio de coccio [:1]
Lemans2003
Re: LMS Silverstone
Messaggioda Lemans2003 » 13/09/2008 - 14:22
io l'ho letto su planet le mans.... [:18] però se tu sai qualcosa in più diccelo [:22]
FJM
Re: LMS Silverstone
Messaggioda FJM » 13/09/2008 - 14:24
io le cose ve le scrivo... ma siete voi che non le leggete...
Lemans2003
Re: LMS Silverstone
Messaggioda Lemans2003 » 13/09/2008 - 14:26
hai scritto che può essere qualsiasi cosa.... anke un modello di serie... però che senso avrebbe presentarla a silvestone? [:8]
jimbo
Re: LMS Silverstone
Messaggioda jimbo » 13/09/2008 - 14:33
Quando si verrà a sapere se la durata delle gare LMS rimarrà sui 1000 km oppure cambierà qaulcosa?
MONZA 2009 TUTTI COLPEVOLI
Lemans2003
Re: LMS Silverstone
Messaggioda Lemans2003 » 13/09/2008 - 14:34
lunedì [:20]
Re: LMS Silverstone
Messaggioda Marco23 » 13/09/2008 - 15:19
Certo che se il motore dovrà durare 2 gare potrebbe essere un segnale che le gare saranno più brevi.
Ultima modifica di Marco23 il 13/09/2008 - 15:41, modificato 1 volta in totale.
Re: LMS Silverstone
Messaggioda Marco23 » 13/09/2008 - 15:20
Lemans2003 ha scritto:L’ACO donnera la possibilité aux teams d’y participer en hybride, sur invitation, mais hors classement, dès 2009.
Cosa significa? Di Francese non so niente... [:57]
Visitano il forum: Nessuno e 22 ospiti
