if you like this is the file ....byeErik Czakoi ha scritto:Ciao,Hello my Friends...I would like to ask,someone could prepare me car skins?I choose this car:Corvette C6.R-Car Number:33.I want a white, light blue car skins,and My team name:[United-ECZ-Corvette C6-Motorsports Team] if it were possible.
Thanks in advance regards, Erik Czakoi...Ciao...
- Allegati
- Chevrolet Corvette C6.R.rar
- (4.08 MiB) Scaricato 100 volte
Bella, molto semplice e "pulita"
- Erik Czakoi
- Nome e cognome: Erik Czakoi
uff51277 ha scritto:if you like this is the file ....byeErik Czakoi ha scritto:Ciao,Hello my Friends...I would like to ask,someone could prepare me car skins?I choose this car:Corvette C6.R-Car Number:33.I want a white, light blue car skins,and My team name:[United-ECZ-Corvette C6-Motorsports Team] if it were possible.
Ciao,Hello Rosmarino yesss,I like very nice skins Thank you very much I will use the championchips...then it can be upgraded to the Updater
verry,verry,verry THANKS!!!
CIAO...
- Erik Czakoi
KaiserMEM ha scritto:Erik Czakoi ha scritto:Ciao,Hello my Friends...I would like to ask,someone could prepare me car skins?I choose this car:Corvette C6.R-Car Number:33.I want a white, light blue car skins,and My team name:[United-ECZ-Corvette C6-Motorsports Team] if it were possible.
hi erik,
surely there will be someone available to paint your skin.
however, your team name is too long. you should choose a shorter one...
Ciao,Hello Marko...I will use this skins to the championchips,painted by me Rosmrino
and my team name: ECZ MOTORSPORTS TEAM...If this is appropriate then it can be upgraded to the Updater
VERRY THANKS...CIAO...
Ultima modifica di Erik Czakoi il 24/04/2013 - 14:01, modificato 1 volta in totale.
- Erik Czakoi
uff51277 ha scritto:[:142]
ROSMARINO FANTASTICO GRAZIE MILLE
Erik Czakoi ha scritto:KaiserMEM ha scritto:Erik Czakoi ha scritto:Ciao,Hello my Friends...I would like to ask,someone could prepare me car skins?I choose this car:Corvette C6.R-Car Number:33.I want a white, light blue car skins,and My team name:[United-ECZ-Corvette C6-Motorsports Team] if it were possible.
hi erik,
your team has been activated. now you can select it in the subscription page
- Erik Czakoi
KaiserMEM ha scritto:Erik Czakoi ha scritto:KaiserMEM ha scritto:Erik Czakoi ha scritto:Ciao,Hello my Friends...I would like to ask,someone could prepare me car skins?I choose this car:Corvette C6.R-Car Number:33.I want a white, light blue car skins,and My team name:[United-ECZ-Corvette C6-Motorsports Team] if it were possible.
hi erik,
OK Marko...Now you have updated...Thank you very much,Grazie mille!!!
- il_pacificatore
- Nome e cognome: dennis grassi
alla prima variante di monza se sali un poco più sul cordolo la vattura diventa gialla nel posteriore
è normale ?
è normale ?
il_pacificatore ha scritto:alla prima variante di monza se sali un poco più sul cordolo la vattura diventa gialla nel posteriore
è normale ?
beh, se entri a velocità e l'auto è anche molto bassa allora certo che è normale.
basta vedere cosa succede nella realtà...
è normale ?
Si se è troppo bassa! perchè rompi l'estrattore/diffusore, prova ad alzarla un po...
- il_pacificatore
- il_pacificatore
KaiserMEM ha scritto:il_pacificatore ha scritto:alla prima variante di monza se sali un poco più sul cordolo la vattura diventa gialla nel posteriore
è normale ?
azzz però io non intendevo propio cosi gialla
stasera ha eseguito l'autopatcher, installato lo skin pak e la modifica dello skin ma mi da sempre mismatch "SLS_GT3.HDV",
sono abituato troppo bene con GtItalia, infatti era da molto tempo che non aggiornavo manualmente le cartelle di rfactor e molto probabilmente ho sputtanato qualche file, chiedo consigli
grazie
grazie
