KaiserMEM ha scritto:cazzarola, potevano fare un trailer anche con le altre macchine
Bandwidth:
96 Kbits/sec per user for server populations less than 10
256 Kbits/sec per user for server populations between 10 and 20
768 Kbits/sec per user for server populations between 20 and 30
While this is track and vehicle dependent a user can expect something close to these approximations on RAM use:
Approximately 200 MB per server instance for server populations less than 10
Approximately 300 MB per server instance for server populations between 10 and 20
Approximately 400 MB per server instance for server populations between 20 and 30
CPU Usage:
This is also dependent on the server population and number of AI drivers but we would account for at least 250 MHz per server instance and on modern CPU, for example if you have a 2.5 GHz dual core you can run 20 servers (10 per core, 10 * 250 Mhz = 2.5 GHz) on that CPU if you have other requirements mentioned above meet. Floating point unit required.
These are just guide lines, there are many things that can effect performance of the server.
, statistiche globali etc e forse per 12 euro all'anno è ancora accettabile.
