[F1 Videotopic] GP d'Australia - Libere+Qualifiche Online
Messaggioda isbenz » 16/03/2007 - 07:08
All'inizio di questa stagione proviamo questa novità...
Videotopic del GP d'Australia
Il post sarà aggiornato con i video delle diverse sessioni.
Libere 1
Mattzel89 ha scritto:One Lap Onboard with Button, taken from the Premiere Onboard-Channel
Filename: MT89_Formula1_2007_Melbourne_FP1_Button_Onboard.avi
Duration: 1 min 58 sec
Filesize: 39.144 KB
Coulthards slides though the fast esses
Filename: MT89_Formula1_2007_Melbourne_FP1_Coulthard_slides.avi
Duration: 0 min 11 sec
Filesize: 4.488 KB
Rubens Barrichello runs wide and goes off
Filename: MT89_Formula1_2007_Melbourne_FP1_Barrichello_off.avi
Duration: 0 min 47 sec
Filesize: 15.512 KB
Jarno Trulli is having a high-speed spin. Footage taken LIVE from the Onboard Channel and the replays are taken form the Supersignal
Filename: MT89_Formula1_2007_Melbourne_FP1_Trulli_spins.avi
Duration: 1 min 36 sec
Filesize: 31.540 KB
Heikki Kovalainen runs wide and goes off in Turn 1
Filename: MT89_Formula1_2007_Melbourne_FP1_Kovalainen_off.avi
Duration: 0 min 40 sec
Filesize: 12.768 KB
Libere 2
Joni ha scritto:Melbourne 2007 FP2 Massa Onboard
[url=http://joni.werty.org/Melbourne07_FP2_Massa_Onboard.avi]Immagine
11MB[/url]
Melbourne 2007 FP2 Fisichella Onboard
[url=http://joni.werty.org/Melbourne07_FP2_Fisichella_Onboard.avi]Immagine
17MB[/url]
Melbourne 2007 FP2 Alonso Onboard as Raikkonen is Chasing him Onboard. :D
[url=http://joni.werty.org/Melbourne07_FP2_Alonso_Onboard_And_Raikkonen_Chasing_Onboard.avi]ImmagineImmagine
10MB[/url]
JJ ha scritto:
Both Jarno Trulli and Nick Heidfeld cut the first chicane
Filename: Albert_Park_2007_F1_FP2_Trulli_Heidfeld.avi
Duration: 0 min 25 sec
Vitantonio Liuzzi spins
Filename: Albert_Park_2007_F1_FP2_Liuzzi.avi
Duration: 0 min 15 sec
Mark Webber runs bit wide
Filename: Albert_Park_2007_F1_FP2_Webber.avi
Robert Kubica goes off and nearly hits the wall
Filename: Albert_Park_2007_F1_FP2_Kubica.avi
Duration: 0 min 24 sec
David Coulthard cuts the first chicane
Filename: Albert_Park_2007_F1_FP2_Coulthard.avi
Duration: 0 min 26 sec
Andrian Sutil runs wide before the pit entrance
Filename: Albert_Park_2007_F1_FP2_Sutil.avi
Duration: 0 min 13 sec
Heikki Kovalainen suffers a technical problem and Rubens Barrichello crashes out
[url=http://www.kolumbus.fi/jj/Albert_Park_2007_F1_FP2_Kovalainen_Barrichello.avi]Immagine
Immagine[/url]
Filename: Albert_Park_2007_F1_FP2_Kovalainen_Barrichello.avi
Duration: 4 min 26 sec
Vitantonio Liuzzi is going utterly too wide
Filename: Albert_Park_2007_F1_FP2_Liuzzi_2.avi
Duration: 0 min 59 sec
Libere 3
JJ ha scritto:Full onboard lap with Christijan Albers
Filename: Albert_Park_2007_F1_FP3_Albers.avi
Duration: 1 min 52 sec
Filename: Albert_Park_2007_F1_FP3_Coulthard.avi
Duration: 0 min 22 sec
Nico Rosberg suffers a technical problem
Filename: Albert_Park_2007_F1_FP3_Rosberg.avi
Duration: 2 min 3 sec
Mattzel89 ha scritto:Albers slides in Turn 1
Filename: MT89_Formula1_2007_Melbourne_FP3_Albers_slides.avi
Duration: 0 min 19 sec
Filesize: 7.136 KB
Felipe Massa locks his brakes approaching pit lane
Filename: MT89_Formula1_2007_Melbourne_FP3_Massa_Lock-Up.avi
Filesize: 6.614 KB
Nico Rosberg stops on the track
Immagine Immagine
Filename: MT89_Formula1_2007_Melbourne_FP3_Rosberg.avi
Filesize: 37.020 KB
Fernando Alonso runs wide and ruins his lap
Filename: MT89_Formula1_2007_Melbourne_FP3_Alonso_wide.avi
Duration: 1 min 2 sec
Filesize: 20.814 KB
Qualifiche
JJ ha scritto:Anthony Davidson runs wide
Filename: Albert_Park_2007_F1_QLF_Davidson.avi
Duration: 0 min 18 sec
Unbelievable situation. Team had forgotten Trulli's trolley jack in the car
Filename: Albert_Park_2007_F1_QLF_Trulli.avi
Duration: 0 min 38 sec
Ralf Schumacher has technical problems
Filename: Albert_Park_2007_F1_QLF_Schumacher.avi
Duration: 0 min 44 sec
Felipe Massa retires gets knocked out due to gear box problems
Filename: Albert_Park_2007_F1_QLF_Massa.avi
Duration: 1 min 27 sec
Replay of Massa going over the curbs
Filename: Albert_Park_2007_F1_QLF_Massa_Replay.avi
Duration: 0 min 30 sec
Mark Webber is following the qualifying from another perspective
Filename: Albert_Park_2007_F1_QLF_Webber.avi
Duration: 0 min 14 sec
Kimi Räikkönen takes the pole position
Filename: Albert_Park_2007_F1_QLF_Raikkonen.avi
Duration: 0 min 36 sec
Kimi Räikkönen Onboard and Parc Ferme
Filename: Albert_Park_2007_F1_QLF_Parc_Ferme.avi
Duration: 2 min 15 sec
kio ha scritto:Strambo problema per Lewis Hamilton
Filename: Hamilton.avi
Duration: 10 sec
Gara
[quote="JJ"]David Coulthard flies over Alex Wurz
[url=http://www.kolumbus.fi/jj/Albert_Park_2007_F1_GP_Coulthard_Wurz.avi]ImmagineImmagine
ImmagineImmagine[/url]
Filename: Albert_Park_2007_F1_GP_Coulthard_Wurz.avi
Duration: 1 min 43 sec
Vi ricordo che questa è solo una mia selezione, altri video sono scaricabili nel forum TBK Fame Flame [richiede registrazione per accedervi] [:15]
Ultima modifica di isbenz il 18/03/2007 - 14:34, modificato 7 volte in totale.
ruotecoperte
Re: F1 - Videotopic GP d'Australia
Messaggioda ruotecoperte » 16/03/2007 - 16:13
isbenz ha scritto:All'inizio di questa stagione proviamo questa novità...
Ottima idea! Lo dico subito al mio amico Net Trasport...
Messaggioda isbenz » 16/03/2007 - 18:55
Aggiunti i video delle libere 2. [:15]
Messaggioda isbenz » 17/03/2007 - 04:44
Aggiornato il primo post con i video delle libere 3. [:3]
